jaydubzok's avatar
jaydubzok
Need help with CM1000v2, packet loss + high latency with spectrum ISP
Hello, I need help determining my issue with my internet, is any of these values out of wack??
<tabindex=-1>Startup Procedure</tabindex=-1>
ProcedureStatusComment
Acquire Downstream Channel297000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnableBPI+
IP Provisioning ModeHonor MDDIPv4 only
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1LockedQAM2561297000000 Hz5.2 dBmV43.8 dB19562177900
2LockedQAM2562303000000 Hz4.8 dBmV43.9 dB19562579000
3LockedQAM2563309000000 Hz4.8 dBmV44.1 dB19562949300
4LockedQAM2564315000000 Hz4.4 dBmV44.1 dB19563286000
5LockedQAM2565321000000 Hz4.1 dBmV43.5 dB19563676700
6LockedQAM2566327000000 Hz3.9 dBmV43.6 dB19564052600
7LockedQAM2567333000000 Hz3.8 dBmV43.3 dB19564393600
8LockedQAM2568339000000 Hz3.9 dBmV43.4 dB19562503300
9LockedQAM2569345000000 Hz3.8 dBmV43.7 dB19565185300
10LockedQAM25610351000000 Hz3.6 dBmV43.6 dB19565561400
11LockedQAM25611357000000 Hz3.4 dBmV43.4 dB19565934500
12LockedQAM25612363000000 Hz3.5 dBmV43.6 dB19566333300
13LockedQAM25613369000000 Hz3.3 dBmV43.5 dB19566683400
14LockedQAM25614375000000 Hz3.1 dBmV43.3 dB19567051600
15LockedQAM25615381000000 Hz3.0 dBmV43.1 dB19567449700
16LockedQAM25616387000000 Hz3.2 dBmV43.4 dB19567715200
17LockedQAM25617393000000 Hz3.1 dBmV43.2 dB19568091100
18LockedQAM25618399000000 Hz3.1 dBmV43.3 dB19568472100
19LockedQAM25619405000000 Hz3.4 dBmV43.5 dB19568823100
20LockedQAM25620411000000 Hz3.3 dBmV43.3 dB19569194100
21LockedQAM25621423000000 Hz3.1 dBmV43.2 dB19569609700
22LockedQAM25622429000000 Hz3.0 dBmV43.3 dB19570031500
23LockedQAM25623435000000 Hz2.8 dBmV43.2 dB19570344900
24LockedQAM25624447000000 Hz2.2 dBmV43.1 dB19570706900
25LockedQAM25625453000000 Hz2.1 dBmV43.1 dB19571129100
26LockedQAM25626459000000 Hz2.0 dBmV43.0 dB19571464800
27LockedQAM25627465000000 Hz2.1 dBmV43.0 dB19571843700
28LockedQAM25628471000000 Hz2.1 dBmV43.1 dB19572183300
29LockedQAM25629477000000 Hz2.0 dBmV42.9 dB19572595600
30LockedQAM25630483000000 Hz2.0 dBmV43.0 dB19572664400
31LockedQAM25631489000000 Hz2.0 dBmV43.0 dB19572659300
32LockedQAM25632495000000 Hz1.9 dBmV42.9 dB19572870500
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
1LockedATDMA224000000 Hz43.3 dBmV
2LockedATDMA330400000 Hz43.5 dBmV
3LockedATDMA436800000 Hz42.8 dBmV
4Not LockedUnknown00 Hz0.0 dBmV
5Not LockedUnknown00 Hz0.0 dBmV
6Not LockedUnknown00 Hz0.0 dBmV
7Not LockedUnknown00 Hz0.0 dBmV
8Not LockedUnknown00 Hz0.0 dBmV
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1Locked0, 1, 233617000000 Hz-1.2 dBmV38.5 dB1108 ~ 29871681827691584271190
2Not Locked000 Hz6.1 dBmV0.0 dB0 ~ 4095000
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
1Locked3, 4, 11, 12, 1395850000 Hz39.3 dBmV
2Not Locked3, 4, 11, 12, 1300 Hz0.0 dBmV
1 Reply
  • FURRYe38's avatar
    No.
    Whats the Event logs page look like?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What is the brand and model of the host wifi router connected to the modem?
    Are you testing for PL with a wired PC connected directly to the back of the modem with out any router in the middle?
