Gtice
Jul 23, 2017Follower
Need help
I have Time warner cable and want to change routers but the r7000 only has a wan connector and the router supplied by twc uses a cable connection,what do I need to do to use the r7000 instead of the twc router
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Gtice
you would have to buy your own modem like the cm400, cm500.
DarrenM
