ArekB
Aug 22, 2025Aspirant
Need satellite firmware for CBK752 system
I have ORBI CBK752. I had some problems so decided to update firmware in the satelites. I updated firmware from the RBS750 (which is the model of the satellite) however now i have V7.2.7.15 (RB softw...
- Aug 22, 2025
Aug 22, 2025Guru - Experienced User
No. You'll need to downgrade the RBS back to v4 FW.
No sure if NG will be putting any v7 FW to the CBR. Only v4 FW is abilable for the CBK750 series which includes any attached RBS. You'll need to leave the RBS at v4 for now.
Orbi CBK Gateway/RBS Satellite Firmware Update FAQ | NETGEAR Communities
