Crystal_RF
Apr 21, 2017Aspirant
Need serious help connecting Netgear Modem and Netgear C3000 router
Okay. I am tech stupid so I hope someone can help. I purchased a Netgear N300 WiFi Cable Modem Router. Model #C3000, hoping to upgrade from a thrift-store find router/modem that is slow & glitchy (at...
michaelkenward
Apr 22, 2017Guru - Experienced User
Not sure that AT&T has given the correct answer. Maybe an expert can step in and explain if this modem will work in router only mode. My instinct is to return the thing and get a modem that is designed for DSL.
However, if you do want to try to get it to work, you will find the manual here:
>>> C3000 | Product | Support | NETGEAR <<<
You might find it useful to read page 73: Change the Router Mode.
Crystal_RF
Apr 22, 2017Aspirant
Thank you for your response and the link/info. I don't doubt AT&T is wrong! I can't afford an expert, and the Netgear modem/router isn't brand new. I purchased it via ebay (not realizing, of course, I was getting the wrong kind until afterward!). I can't send it back or get a refund, nor can I afford to pay someone to help me. (I'm still using my original Dell monitor, mouse & keyboard from over 15 yrs. ago and the tower I have is a replacement POS from an 'expert' who sold me a 'customized, top-of-the-line, new computer' (turned out it was made with parts/pieces that were so old they were no longer under any kind of warranty... I ended up having no other option but to take another that he just had 'around', as even the BBB wouldn't get me my money back after the 1st one's hard drive went in less than a month). Point being, I don't have anything that is even remotely close to new, so we've tried to 'upgrade' as inexpensively as possible.)
- TheEtherApr 22, 2017Guru
I'm sorry to say that if your AT&T connection uses DSL, then the C3000 will not work. The C3000 is a DOCSIS cable modem, not DSL.
- Crystal_RFApr 23, 2017Aspirant
Thank you, that's what I was afraid of, once I got the item & read on everything (box/paper inside) that it was a "Cable" modem/router. I didn't know that you had to have ones specifically for whatever way you get your ISP. AT&T kept insisting ti would work, though. Ugh. money we didn't really have down the drain! Expensive lesson.
