epochdad
Jan 23, 2022Aspirant
Need to change MAC address on NETGEAR Nighthawk C7800
I left an open email relay on my machine and of course it was exploited and now my static IP is listed in sorbs and spamhaus. I have begged them to delist my IP but they said they can't and I have to contact comcast. I contacted comcast and they wont issue me a new IP address. I am unable to access many forums due to this problem and I was curious to know if there's a way to "spoof" the MAC address so my static IP will change?
I've tried unplugging the router for a full 24+ hours to see if the IP would change it did not.
Netgear has set up a community forum specifically for the Cable Modem products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
Thank you. - FURRYe38Guru - Experienced User
Any progress on this?
