Amuuz's avatar
Amuuz
Follower
Oct 31, 2015
Need to set the time on my C3700
Recently I purchased a refurbished NetGear C3700.  Works fine, but the time is wrong and is screwing up my LAN.  Is there ANY way to change the time on this model?  Firmware I see can be an issue and is usually handled by the ISP, but my ISP does not have the firmware to push to me, so I need a work around.  Is there any way to set the time and/or update the firmware??
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Amuuz
    Those should both be pushed out by the ISP have you tried a factory reset yet that may correct the issue once it connects back up to the Internet.
    DarrenM
