enguerrand
Jun 22, 2017Follower
needs adapter(s)?
Just bought C6300 - will install next week when WOW is installed in my home.
In the meantime, box says "Use laptop with 3x3 450 Mbps adapter like Centrino 6300/5300 for maximum performance."
Also: "Use with an 802.11ac adapter lie NETGEAR A6200 for maximum performance."
What is this? Do I need adapters in order to use this device?
Thank you.
PS: I use a MacBook laptop.
could it be that you posted in wrong forum because i don't see what this has to do with the arlo cam.
- DarrenMSr. NETGEAR Moderator
Hello enguerrand
No you no not need a adapter to use your macbook.DarrenM
