Craigsv6
Jun 27, 2019Follower
Netgear ac750
Hi. We brought a netgear nighthawk Ac750 today and have had it set up. Connected it to the app on my mobile phone and done a firmware update then all of a sudden the router turned of and now just the power light flashes green and none of the other lights come up so can no longer connect to it. Is there a way where we can fix this issue as have done everything google has told us to do and it is still not working.
1 Reply
> [...] netgear nighthawk Ac750 [...]
"AC750" is a speed, not a model number. Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier. Look at the product label for the actual model
number.> [...] Connected it to the app [...]
Which "the app"?
> [...] the power light flashes [...]
You may be a candidate for the TFTP recovery scheme. See, for
example:https://community.netgear.com/t5/x/x/m-p/1622096#M102004
> [...] have done everything google has told us to do [...]
The non-psychics in your audience may have no idea what you read
where.
