trigger113
Jan 23, 2016Tutor
netgear C3700-100NAS sporatic web browsing issues (able to ping / not able to browse).
I have a C3700-100NAS Router/Modem for about 3 months now with comcast as my Internet Service Provider (ISP). Upon first install around November of 2015, I had issues getting the asset to work ap...
Eric19
Jan 23, 2016Initiate
I'm having the same problems. a temporary fix is to log into your C3700, go to advanced home tab, then on the internet port area, click on connection status. another small window will popup. you can click "renew" to renew your lease. For me it immediately makes the internet work - until the next time which could be hours or minutes.
- trigger113Jan 23, 2016Tutor
I'll give that a swagger Eric and see if that helps.
- PainInMyNetJan 24, 2016Initiate
I'm having the EXACT same problem, also using Comcast and same Netgear model. I just started looking at my log yesterday because of other suspicious behaviour I've noticed on personal accounts like banking, gaming, etc.
Releasing, power cycling, renewing, and changing to Google DNS servers did not change my IP address. Here is my most recent log
[DoS attack: SYN Flood] from 152.163.13.6, port 80 1 Sun Jan 24 13:13:02 2016 192.168.0.23:51854 152.163.13.6:80 [DoS attack: SYN Flood] from 69.172.216.111, port 80 1 Sun Jan 24 13:12:19 2016 192.168.0.23:51684 69.172.216.111:80 [DoS attack: SYN Flood] from 74.119.118.94, port 80 1 Sun Jan 24 13:12:13 2016 192.168.0.23:51669 74.119.118.94:80 [DoS attack: SYN Flood] from 69.194.244.11, port 80 1 Sun Jan 24 13:12:09 2016 192.168.0.23:51640 69.194.244.11:80 [DoS attack: SYN Flood] from 173.241.250.221, port 80 1 Sun Jan 24 13:11:52 2016 192.168.0.23:51505 173.241.250.221:80 [DoS attack: SYN Flood] from 184.25.254.64, port 80 1 Sun Jan 24 13:11:05 2016 192.168.0.23:51381 184.25.254.64:80 [DoS attack: SYN Flood] from 69.194.244.11, port 443 1 Sun Jan 24 13:10:55 2016 192.168.0.23:51351 69.194.244.11:443
[DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 1 Sun Jan 24 12:55:47 2016 73.71.107.103:55949 75.75.75.75:53 Ping has also been disabled since installation, which was about 8 months ago. I'm beginning to think there's a vulnerability in the router Netgear is unaware of or unable to address. Any other suggestions would be great.
Thanks
- MeIMyselfJan 26, 2016Initiate
I suggest you read what is at this link http://searchsecurity.techtarget.com/definition/SYN-flooding then go to the page in Genie under advanced setup wan setup and make certain that none of those little check boxes are checked for starters.
