trigger113
Jan 23, 2016Tutor
netgear C3700-100NAS sporatic web browsing issues (able to ping / not able to browse).
I have a C3700-100NAS Router/Modem for about 3 months now with comcast as my Internet Service Provider (ISP). Upon first install around November of 2015, I had issues getting the asset to work ap...
PainInMyNet
Jan 24, 2016Initiate
I'm having the EXACT same problem, also using Comcast and same Netgear model. I just started looking at my log yesterday because of other suspicious behaviour I've noticed on personal accounts like banking, gaming, etc.
Releasing, power cycling, renewing, and changing to Google DNS servers did not change my IP address. Here is my most recent log
| [DoS attack: SYN Flood] from 152.163.13.6, port 80 | 1 | Sun Jan 24 13:13:02 2016 | 192.168.0.23:51854 | 152.163.13.6:80 |
| [DoS attack: SYN Flood] from 69.172.216.111, port 80 | 1 | Sun Jan 24 13:12:19 2016 | 192.168.0.23:51684 | 69.172.216.111:80 |
| [DoS attack: SYN Flood] from 74.119.118.94, port 80 | 1 | Sun Jan 24 13:12:13 2016 | 192.168.0.23:51669 | 74.119.118.94:80 |
| [DoS attack: SYN Flood] from 69.194.244.11, port 80 | 1 | Sun Jan 24 13:12:09 2016 | 192.168.0.23:51640 | 69.194.244.11:80 |
| [DoS attack: SYN Flood] from 173.241.250.221, port 80 | 1 | Sun Jan 24 13:11:52 2016 | 192.168.0.23:51505 | 173.241.250.221:80 |
| [DoS attack: SYN Flood] from 184.25.254.64, port 80 | 1 | Sun Jan 24 13:11:05 2016 | 192.168.0.23:51381 | 184.25.254.64:80 |
| [DoS attack: SYN Flood] from 69.194.244.11, port 443 | 1 | Sun Jan 24 13:10:55 2016 | 192.168.0.23:51351 | 69.194.244.11:443 |
| [DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 | 1 | Sun Jan 24 12:55:47 2016 | 73.71.107.103:55949 | 75.75.75.75:53 |
Ping has also been disabled since installation, which was about 8 months ago. I'm beginning to think there's a vulnerability in the router Netgear is unaware of or unable to address. Any other suggestions would be great.
Thanks
trigger113
Jan 26, 2016Tutor
PainInMyNet wrote:I'm having the EXACT same problem, also using Comcast and same Netgear model. I just started looking at my log yesterday because of other suspicious behaviour I've noticed on personal accounts like banking, gaming, etc.
[DoS attack: SYN Flood] from 152.163.13.6, port 80 1 Sun Jan 24 13:13:02 2016 192.168.0.23:51854 152.163.13.6:80 [DoS attack: SYN Flood] from 69.172.216.111, port 80 1 Sun Jan 24 13:12:19 2016 192.168.0.23:51684 69.172.216.111:80 [DoS attack: SYN Flood] from 74.119.118.94, port 80 1 Sun Jan 24 13:12:13 2016 192.168.0.23:51669 74.119.118.94:80 [DoS attack: SYN Flood] from 69.194.244.11, port 80 1 Sun Jan 24 13:12:09 2016 192.168.0.23:51640 69.194.244.11:80 [DoS attack: SYN Flood] from 173.241.250.221, port 80 1 Sun Jan 24 13:11:52 2016 192.168.0.23:51505 173.241.250.221:80 [DoS attack: SYN Flood] from 184.25.254.64, port 80 1 Sun Jan 24 13:11:05 2016 192.168.0.23:51381 184.25.254.64:80 [DoS attack: SYN Flood] from 69.194.244.11, port 443 1 Sun Jan 24 13:10:55 2016 192.168.0.23:51351 69.194.244.11:443
[DoS attack: TCP- or UDP-based Port Scan] from 75.75.75.75, port 53 1 Sun Jan 24 12:55:47 2016 73.71.107.103:55949 75.75.75.75:53
Thanks
PainInMyNet,
First, I like th name! ;)
Second, did you notice if comcast upgraded your firmware around 1/1/2016 at 00:30:00?
Also, if you disable the "DOS" feature on your Netgear Modem, do your symptoms disappear (the symptoms being your internet explorer/firefox/browser web pages don't load....)?
- PainInMyNetJan 31, 2016Initiate
Page loading does seem a little better, but I'm concerned about security more than anything. I don't see where anything may have changed with Comcast settings on my Netgear. All my checkboxes on the WAN setup page were already unchecked, but page loading improved after checking "Disable Port Scan and DoS Protection."
