samuelatlas
Dec 03, 2016Aspirant
Netgear C3700 Modem/Router
I cant telnet into my router is there some thing i doing wrong?
DarrenM
Dec 05, 2016Sr. NETGEAR Moderator
Hello Samuelatlas
Can you give some more detail on the steps you have done and what issues you get when trying to telnet.
DarrenM
- samuelatlasDec 05, 2016Aspirant
ok i have putty installed i type in my ip address and choose telnet. i get "network error :connection timed out."
- DarrenMDec 06, 2016Sr. NETGEAR Moderator
Hello samuelatlas
Have you gone to 192.168.0.1/debug.htm to enable telnet.
DarrenM
- samuelatlasFeb 02, 2017Aspirant
I figured it out the router i have does not support telnet. I should have goten the more expensive one. according to net gear I need the business class router not the home one.
