JimCurry's avatar
JimCurry
Follower
Dec 19, 2023
Netgear C3700 Question
I've used the C3700 with Xfinity since 2015.  We had a power failure and after power restoration none of my computers, phones, cameras, tvs see either the 2.4 or 5 wifi signals.  The ethernet connection works which is how I'm connected here.
I've turned it on/off, unplugged, pushed the wifi button in front, but nothing seems to work.  Any suggestions?
Jim Curry
  • FURRYe38's avatar
    "tvs see either the 2.4 or 5 wifi signals." Did you mean neither?
    Try a factory reset on the modem by pressing the reset button for 15 seconds then release.
  • plemans's avatar
    Did you push and hold for at least 2 seconds on the wifi on/off button?
    Also, it might be time to upgrade. Thats a pretty low performing modem with a N600 router.
    Its pretty old/slow. Unless you're paying for the most base model speeds, you might see a nice improvement in speeds by upgrading to something from this generation
