Tuckab's avatar
Tuckab
Follower
May 18, 2018
Netgear C3700
My Netgear is working but connection speed is very slow in event logs it says critical 3 T3 timeout it worked perfectly fine now it doesn’t don’t know what happened
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    This is typically a ISP issue you may need to contact your ISP and have them investigate your cable lines.
    DarrenM
