Augie74's avatar
Augie74
Netgear C6300 - AC1750 Cable Modem WiFi Router
Can I use the eithernet port on my netgear C 6300 cable modem/router to run a Google Nest Wifi Pro- Wifi 6E Home Wifi System? If so will I have all the functions of the Google Nest system that I would have if I was using a cable modem without  router?
Thank you in advance
  • Thank you!!!  It worked. I have connected a mesh network to my cable modem.
