Loooo
Nov 21, 2022Aspirant
Netgear C6300 Connected to internet but no Wifi
Had the router for a couple years now and never had issues with it. Today when I got home I have no Wi-Fi and hitting the Wi-Fi button on the modem itself does nothing. Have tried to factory reset with reset button but if the Wi-Fi button comes on it doesn't connect to internet then resets again without Wi-Fi.
Is the wifi on/off light on or off?
When you hit it, did you hold it for 2 seconds?
- LooooAspirant
Both the Wifi light and the one above it is not lit up. Also the 2.4 and 5.0 lights are off. I did hold it for two seconds.
- LooooAspirant
Are you able to log into it with a hardwired device?
