TylerChambers99
Aug 23, 2017Follower
Netgear c6300 only putting out 30-30Mbps internet speeds when wired/wireless
Hello all, i just bought this router and set it up. everything is going smoothly untill i check my internet speeds at speedtest and fast.com; i then see that my speeds are not going above 30mbps. i am paying cox for 300/50mbps and it is not even approaching that. the upload speed is fine though. any thoughts or suggestions? i am running firmware V2.01.14 if that helps.
1 Reply
- vkdeltaNETGEAR Employee Retired
make sure Cox has sent correct config file to your modem. This is most likely config file issue.
