xtamil2002
Jan 28, 2023Follower
Netgear C6900 as Router only
Hi
Can the Netgear AC 1900 Wifi Cable Modem Router Model C6900 be used as a router - only. My current ISP insists on getting a modem from them. I want to know if i can use C6900 as the router alone. I do see the modem does not have a separate WAN port. It does have 4 LAN ports. I see that it is possible to use it as Modem only
https://kb.netgear.com/27191/How-do-I-set-my-NETGEAR-cable-modem-router-to-function-as-a-modem-only
Is it possible to use it as Router only ??
