meadmax
Jan 16, 2016Aspirant
Netgear C7000 / Nighthawk AC1900 Cable Modem Router combo
I have a new (yesterday) AC1900 Cable/WiFi combo router that I connected to my provider (Comcast) replacing an older device, which, in the previous configuration I had the cable modem connected to th...
meadmax
Jan 18, 2016Aspirant
If I put everything on the ProSafe LAN then I only get 25-40Megabits download speed. There is a problem somewhere in the Prosafe that prevents it from using the entire bandwidth. I have been battling this for several days now.
A new thread potentially - Interestingly, if I connect a standard AC1900 to my N600 cable modem I lose half the speed too. The only way I can get the full speed is with the AC1900Cable Wifi combo device.
TheEther
Jan 18, 2016Guru
According to the datasheet (link), it looks like the FV336G takes a pretty bit performance hit while doing either VPN or IPSec encryption. But, I assume you can configure it to only encrypt work traffic and leave all Internet traffic untouched.
You may also want to check your Ethernet cables. One of them could be bad.
