kylewburns
Apr 20, 2018Aspirant
Netgear C7000-100NAS relentless T3 Time-outs and rebooting
About 2 months ago, my Netgear C7000-100NAS started having at least 5 reboots a day (sometimes up to a dozen times a day!!). Error logs read T3 timeouts relentlessly. Firmware Version V1.01.28
There are no splitters, I'm running directly to the wall. I had Comcast techs come out and they said everything looks good, strong signals, etc., and suggested it might be the modem/router having troubles. So I'm stuck between an ISP and a modem manufacturer. Can someone PLEASE help, I work from home and rely on a consistent connection, and am not getting it.
Here is the most recent log (after recently be cleared FYI, but just imagine T3 error logs 5-12 times a day):
| Time | Priority | Description |
| 1970-1-1, 00:00:38 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=********I'M HIDING MAC ADDRESS***********;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:46 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=********I'M HIDING MAC ADDRESS***********;CMTS-MAC=00:01:5c:67:64:79;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:37 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=********I'M HIDING MAC ADDRESS***********;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:44 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=********I'M HIDING MAC ADDRESS***********;CMTS-MAC=00:01:5c:67:64:79;CM-QOS=1.0;CM-VER=3.0; |
| 2018-4-20, 06:17:18 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=********I'M HIDING MAC ADDRESS***********;CMTS-MAC=00:01:5c:67:64:79;CM-QOS=1.1;CM-VER=3.0; |
| 1970-1-1, 00:00:45 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=********I'M HIDING MAC ADDRESS***********;CMTS-MAC=00:01:5c:67:64:79;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:37 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=********I'M HIDING MAC ADDRESS***********;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:40 | Notice (6) | WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:40 | Notice (6) | WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:45 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| 2018-4-20, 16:18:44 | Notice (6) | WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2018-4-20, 16:21:28 | Warning (5) | MDD message timeout;CM-MAC=********I'M HIDING MAC ADDRESS***********;CMTS-MAC=00:01:5c:67:64:79;CM-QOS=1.1;CM-VER=3.0; |
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- vkdeltaNETGEAR Employee Retired
Pls post the network logs as well
- kylewburnsAspirantWhere are network log specifically located?
right where you found "event logs" .. there would be another option on left hand column for "logs" and they will have all the network logs showing if Internet disconnected or not.
