bob7bob7's avatar
bob7bob7
netgear c7000 ac1900- lan port leds
should both green and amber led's be on when ethernet cable is pluged into one of the 4 lan ports on back of unit, and then pluged into computer. I only get the amber led. My speed seems to be about half what it should be.
  • > Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
       C7000 or C7000v2?  Look for "Model" on the product label.
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual.  Read.  Look for the
    LED descriptions and "Troubleshoot".
    > [...] ethernet cable is pluged into one of the 4 lan ports on back of
    > unit, and then pluged into computer. [...]
       Try a different cable?  Try a different port?  "computer" is not a
    very detailed description of that device.  Is its Ethernet interface
    gigabit-capable?
    > [...] My speed seems to be about half what it should be.
       What is your "My speed", measured how?  What should it be?
    • bob7bob7's avatar
      bob7bob7
      c7000, at work dont have unit with me
      looked at manual, saw nothing about rear lan led's
      test speed at isp website 50mbps wi-fi 72mbps ethernet . download speed
      paying for 200mbps, dont know about computer having gig ethernet, but about 7 years old. HP desk top. Friends 2 year old lap top will do 100mbps on ethernet
      • bob7bob7's avatar
        bob7bob7
        tried 3 differant cables
        dont know if i need to set something up on netgear modem website
