Billyb86
Nov 12, 2019Follower
Netgear C7000
Hello, i am thinking of purchasing the Netgear Nighthawk C7000, i currntly have the Hitron CGNVM-3582 with the gig plan from my provider. I have had a lot of trouble out of the Hitron, would i theC7000 be a down grade? The highest My Mbps have gotten thru my ps4 pro is 300 download. Thanks for any advice!
1 Reply
You'll need to contact your ISP and ask them what is supported for there 1Gb plans. Most ISP required a DOCSIS 3.1 supporting modem. The C7000 is only DOCSIS 3.0. Also 1G need 32x8 channel bonding. The c7000 only supports 24x8.
Look into the C7800 which is DOCSIS 3.1 supporting.
Billyb86 wrote:Hello, i am thinking of purchasing the Netgear Nighthawk C7000, i currntly have the Hitron CGNVM-3582 with the gig plan from my provider. I have had a lot of trouble out of the Hitron, would i theC7000 be a down grade? The highest My Mbps have gotten thru my ps4 pro is 300 download. Thanks for any advice!
