TechieMafaka
Oct 09, 2019Guide
Netgear C7000v2 Cable Wifi Router Rebooting Itself SOLVED
 I purchased the Netgear C7000v2 Cable Wifi Router in early 2019 and the unit would reboot itself randomly for months. I tried everything you could possibly think of from changing every setting to con...
- Nov 08, 2019
I have had the same problem with 2 of the Netgear units. I am going to try your idea and keep my fingers crossed.
95jn
Nov 08, 2019Initiate
- TechieMafakaNov 09, 2019Guide
Yeah it's helped a lot. I still think this router is a piece of junk and I think Netgear knows it. BTW this is my third replacement. I really feel like all routers need some sort of cooling fan.
- myerswNov 09, 2019Master
There have been reports on this site of folks opening the router and finding that the heat sink grease was dried out and not working any more. New grease and was a new router, except for the buggy firmware. There is heat sink grease and then there is heat sink grease. Those of us who build PC's see the difference. Cheap drys out quick.
You're talking about thermal paste, right? I wouldn't doubt they use cheap everything. The fan solution works very well. The router stays cool all the time. I wish there were more options for cable router combos on the market. There are very few and they all suck.
