TechieMafaka
Oct 09, 2019Guide
Netgear C7000v2 Cable Wifi Router Rebooting Itself SOLVED
I purchased the Netgear C7000v2 Cable Wifi Router in early 2019 and the unit would reboot itself randomly for months. I tried everything you could possibly think of from changing every setting to con...
- Nov 08, 2019
I have had the same problem with 2 of the Netgear units. I am going to try your idea and keep my fingers crossed.
TechieMafaka
Nov 11, 2019Guide
i kinda figured. What modem did you purchase?
myersw
Nov 11, 2019Master
TechieMafaka wrote:i kinda figured. What modem did you purchase?
Look at my sig maybe???? Got to look around. ;)
You do have to be careful and buy one that the ISP has on their approved list to be sure it will work.
