JAC-SDS
Apr 19, 2023Aspirant
Netgear CAX80 - OpenVPN
Hi,
Having an issue with a CAX80 router. Recently factory reset, almost every setting is default - except it for it being setup as an OpenVPN server, this part works and a laptop with the OpenVPN client can connect to it successfully from outside the network and is given a 192.168.1.# address. It needs to RDP to a device on the router's local network which is 10.0.0.#. They are not able to route between each other even though the "All sites on the Internet & Home Network" is enabled within the VPN Service configuration.
The Static routes menu is not under Advanced - Advanced Setup to set this up manually.
Latest firmware is installed.
Might be missing something obvious, any ideas?
Thanks
- KitsapMaster
JAC-SDS wrote:Hi,
Thanks
Through the VPN connection, you are not going to be able to connect devices between two different sub-nets.
You are going to have to put the router that hosts the VPN server and the device you are trying to RDP to on the same sub-net.
- JAC-SDSAspirant
The way it's setup as the moment -
Netgear router hosting OpenVPN - 10.0.0.#
Local device - 10.0.0.#
External laptop - when connected to OpenVPN - 192.168.1.#
At some point I read that connecting devices were given a different subnet then allowed access with the "All sites on the Internet & Home Network" option. It's seperated the networks by default, what do I need to do - manually change the IP of the connecting device to 10.0.0.#?
Thanks,
