FastEddie99's avatar
FastEddie99
Netgear CM 500 slow speed
I have a Netgear CM 500 modem with a TP-Link AC1200 modem. Both are "Certified" by Xfinity. My service is 400 mbps from XFinity. I can only get 65 mbps wireless. With a direct ethernet connection to the Netgear CM500 router I get 95 mbps. I am in a condo complex with a main line feed and nobody else has this problem. I tried connecting my PC directly to the Netgear CM 500 which I assume you should be able to do and this doesn't work. No connection. With the router connected I can get wireless and ethernet from it but not directly to the CM 500. Are there any configuration tweaks I can do. The TP-Link and my PC each have 802.11ac capabilities.
