tapakai
Dec 18, 2016Aspirant
Netgear CM1000 activation woes
This post is for the Netgear CM1000 Docsis 3.1 gigabit modem. The tag for this product is still not available maybe beacause it does not officially ship for a few more days. I used the CM500 as a pla...
- Dec 20, 2016
Hello Tapakai
This is a known issue with the FW on this unit I suggest contacting support for a RMA to resolved the issue with the CM1000.
http://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
Scrigs
Feb 10, 2017Tutor
I spent another hour on the phone with a supervisor in tier 2 support two evenings ago. He finally admitted it sounds like an issue on their end and they areally working on updates to stabilize the connectivity. I still don't understand why 4 weeks ago when I hooked the first one up it provisioned right away and worked flawlessly for 2 weeks, then all of a sudden went offline and wouldn't work. The replacement won't come online at all even with the 20 different things they had me try. He is supposed to call me back the 15th with some type of update, even if it means telling me he doesn't have any more info. He did tell me there is only 1 modem with DOCSIS 3.1 that they currently support and I dont remember the name of it but it wasn't Netgear.
