johnalameda
Jul 05, 2022Aspirant
Netgear CM1100 V2.01.02 - Listening on both 192.168.0.1 and 192.168.100.1
Hi, I have a Netgear CM1100 using firmware version V2.01.02. I did a routine scan on my network using NMAP and noticed that the modem is listening on both 192.168.0.1 and 192.168.100.1. I know that...
- Jul 09, 2022
Was NOT able to access the modems web page at 192.168.0.1 whatsoever.
Jul 06, 2022Guru - Experienced User
And this is with out a external router connected to the modem?
johnalameda
Jul 06, 2022Aspirant
Yes that's correct. I am directly connected to the modem. There is no external router hooked up to the modem.
- FURRYe38Jul 06, 2022Guru - Experienced User
Are both accessible if the external router is connected and the router is set for .0.1? I presume that should be accessible then. The .100.1 should be though.
- johnalamedaJul 06, 2022Aspirant
Thanks FURRYe38 for the input. So just to be clear, you would like me to attach the external router directly to the cable modem and change the external router's IP (currently .1.1) address to .0.1. Then attach my laptop to the external router and try to access http://192.168.0.1. correct? Is the expectation that I would go to my external router's admin portal? I will give this a try and get back to you.
Without the external router hooked up right now, if I access http://192.168.0.1 from a browser, I get a prompt for login credentials (which looks similar to http://192.168.100.1) but I am unable to log into it. I tried my admin credentials as well as the default username and password (admin/admin). Nothing worked.
Yes please.
