johnalameda
Jul 05, 2022Aspirant
Netgear CM1100 V2.01.02 - Listening on both 192.168.0.1 and 192.168.100.1
Hi, I have a Netgear CM1100 using firmware version V2.01.02. I did a routine scan on my network using NMAP and noticed that the modem is listening on both 192.168.0.1 and 192.168.100.1. I know that...
- Jul 09, 2022
Was NOT able to access the modems web page at 192.168.0.1 whatsoever.
Jul 08, 2022Guru - Experienced User
What maybe the onboard web server that hosts the modems web page.
So I took out my CM1100 and 1200 today and check them both.
Both don't exhibit this issue with .0.1 address being made available.
- johnalamedaJul 09, 2022Aspirant
Thanks FURRYe38 for checking this. Are you able to access http://192.168.0.1 from a browser? When I tried pinging 192.168.0.1, the pings were lost similar to your results. However, I was able to access it from the browser. Also, I was able to scan it with NMAP ( nmap 192.168.0.1 ) as well.
- FURRYe38Jul 09, 2022Guru - Experienced User
