Nuklear92
Feb 28, 2020Aspirant
Netgear CM1200 Modem (Question)
Quick question, when the downstream light is blinking I read that it means it’s scanning for new channels. However, it’s been more than 24hs already that the Modem started blinking the light for Downs...
- Feb 29, 2020
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Nuklear92 wrote:
By the way, I rebooted the Modem through there and the downstream light stopped blinking. However, I know it might do it again in the future. I just want to know if always have to manually reboot the router when that happens or if the light stops blinking automatically even though it was already 72hrs after it started blinking. 🤷♂️
Hello1981
Mar 13, 2020Aspirant
What cable internet service do you guys have? I called spectrum here in California and they told me that I can’t use my own modem if Iam on gig speed.. I have always used my own cable modems. But I was surprised to hear that, she stated that gig service requires their modem ?
- plemansMar 15, 2020Guru - Experienced User
The only non-spectrum approved modem for gig service I can see is the CAX80 but its not released yet.
https://www.spectrum.net/support/internet/compliant-modems-charter-network/
