watersu
Jan 10, 2018Initiate
NETGEAR CM600 (24x8) DOCSIS 3.0 Cable Modem upstream frequency
Hi, I know that; CM600, 24x8 docsis 3.0 cable modem has a processor of Broadcom BCM3384, But I also need to know this modems; upstream freequency ? As my service provider may utilize different fre...
vkdelta
Jan 10, 2018NETGEAR Employee Retired
it would lock to exact frequency in your area in US ISP.
it would not matter if the device is 5-42 or 5-85 .. since Most US ISPs have 5-42 MHz always reserved for US frequencies.
watersu
Jan 11, 2018Initiate
Ty for your reply,
But im in Tr (Turkey), here we have only one cable provider; https://www.turksatkablo.com.tr/
They have different setups in different areas; a mix of us and euro standarts,
I may transfer modem between 2-3 cities,
So, its a technical detail for me to learn upstream frequency of CM600,
where can i mail netgear.com ?
For example if I search pdf of Motorola MB7420, it writes, "5 to 85 MHz edge to edge" as its 16x4 i wont buy it.
- vkdeltaJan 11, 2018NETGEAR Employee Retired
Our modems are not certified for turkey and this device is not CE (european) certified. We dont suggest you to take this to Turkey. and power supply is North american as well.
