mlipink
Aug 19, 2017Aspirant
Netgear Gateway AC1750 Modem Router C6300 Time is Wrong
I have a Netgear gateway AC1750 C6300 on which the TIME is WRONG. The manual states you can change this under Advanced > Security > Schedule, but there is no such setting. What is ironic, is that...
- Aug 26, 2017
Returned to Best Buy as it does not do what it promised, nor what I want. Access blocking per schedule simply does not work.
DarrenM
Aug 22, 2017Sr. NETGEAR Moderator
Hello mlipink
The time is set by the ISP CMTS which does not follow daylight savings so no manual way to get the current time.
DarrenM
- mlipinkAug 22, 2017Aspirant
O.K. Thanks.
I'm assuming I won't be able to implement a curfue schedule per device then. Like I said, if any access blocking is implemented per schedule, no matter how small a time frame, all access is cut off all day.
I guess I'll be returning, because unplugging every night to keep the kids off is not an option.
