mlipink
Aug 19, 2017Aspirant
Netgear Gateway AC1750 Modem Router C6300 Time is Wrong
I have a Netgear gateway AC1750 C6300 on which the TIME is WRONG. The manual states you can change this under Advanced > Security > Schedule, but there is no such setting. What is ironic, is that...
- Aug 26, 2017
Returned to Best Buy as it does not do what it promised, nor what I want. Access blocking per schedule simply does not work.
vkdelta
Aug 22, 2017NETGEAR Employee Retired
who is your ISP? Is the ISP not sending ToD time itself or is it just off by 1 hour?
please provide event log?
mlipink
Aug 22, 2017Aspirant
| Aug 19 2017 13:31:02 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Time Not Established | Critical (3) | No Ranging Response received - T3 time-out |
| Aug 19 2017 13:16:48 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Aug 17 2017 21:34:44 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
