mlipink's avatar
mlipink
Netgear Gateway AC1750 Modem Router C6300 Time is Wrong
I have a Netgear gateway AC1750  C6300  on which the TIME is WRONG.  The manual states you can change this under Advanced > Security > Schedule, but there is no such setting.  What is ironic, is that...
  • mlipink's avatar
    Aug 26, 2017
    Returned to Best Buy as it does not do what it promised, nor what I want. Access blocking per schedule simply does not work.
