mzbehaven365's avatar
mzbehaven365
Follower
Dec 03, 2015
Netgear Genie 3700
Is it normal for one of my lights on my Netgear modem to turn amber and back to green??
The 2nd light after the power light is the one Im asking about. I dont believe that Ive experienced any outages or anything (Ive not lost my internet connection) as far as I know.
Just want to know if this is normal and if I should expect my modem to go out any time soon.
I have Windows 10.
I have an HP laptop
My ISP is Cox
And my I receive service via cable.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello mzbehaven365
    If you haven't seen any performance issues or dropping of internet then you should be fine. let us know if you find any odd things happening if so everyone here is happy to help with the issues.
    DarrenM
    • mattingly23's avatar
      mattingly23
      the light next to the power light turns amber and i lose internet then after a few minutes it comes back on
      • DarrenM's avatar
        DarrenM
        mattingly23
        I would check your cords first it could be a cable splitter causing a issue may want to remove it or replace it and see if the connection is better also check with your ISP see if they see issues with the connection.
        DarrenM
