Coldsteel327's avatar
Coldsteel327
netgear genie does not save my settings
i log into netgear genie and modify the settings i want for each device connected to my network. however, it will not keep these settings. what is going on? how do i fix this?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Coldsteel327
    Have you tried to uninstall genie and download the latest and reinstall?
    DarrenM
    • Coldsteel327's avatar
      Coldsteel327
      i downloaded the newest version BEFORE i asked for help. i am very frustrated with all of this. netgear genie does not save my settings such as when i block a device from my network. and then sometimes it won't even give me the option to block the devices after i have blocked them and they somehow majically become unblocked. if i can not resolve these issues, then i will find another router from a different company that will not cause me such problems.
    • greatgeko's avatar
      greatgeko
      is there any solution to this issue I am also having the same problems and it has been well over a week that the OP has posted his issue with 0 response.
      here is my information
      model: WNDR4300
      OS: windows 10
      firmware: V1.0.2.80
