gamalielreeves
Aug 26, 2015Aspirant
Netgear Genie
Good evening. Recently purchased a Netear C3700 router and I have also downloaded the Netgear Genie. I attempted to do the set-up, however the program will not allow me to continue, advising me to ...
Babylon5
Aug 26, 2015NETGEAR Employee Retired
You can also try setting up the router by logging into its web interface using a Web Browser. This will give you direct control over the router settings and you should be able to run a setup wizard from there. Do you have the manual for the C3700? http://www.downloads.netgear.com/files/GDC/C3700/C3700_UM_21Aug2014.pdf
- gamalielreevesAug 27, 2015Aspirant
Andy thank you so very much. Your suggestion worked. Set-up has been completed.
