DewyB's avatar
DewyB
Netgear GS608v3 not opening control panel
I have tried routerlogin.com and .net, 192.168.0.1, 192.168.1.1, and performed an ipconfig and tried my defalut gateway ip. NOTHING opens the control panel so I can open a port.
I should get a pop up asking for password and user name, but I just get "Site can't be reached, ip address refused to connect".
About to pull out my hair and bash router with hammer. No place to insert a paper clip and reset to factory settings either.
  • > Netgear GS608v3 not opening control panel
       A GS608v3 is an unmanaged switch.  It has no "control panel".
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get what you can find.  Read.
    > [...] About to pull out my hair and bash router with hammer. [...]
       You'll need to find a "router" first; a GS608v3 is not a router.
    > [...] No place to insert a paper clip and reset to factory settings
    > either. [...]
       Unmanaged switch.  Not a router.  No "factory settings".
    > performed an ipconfig and tried my defalut gateway ip. [...]
       "tried" how?  Some web browser or other?  On some computer/device or
    other?  Connected how to what?  What, exactly, was your "my defalut
    gateway ip"?  What, exactly, happened when you "tried" each of these
    things?
       Do you _have_ a router, or only the GS608v3?  What, exactly, is
    connected to what, exactly?  What, exactly, are you trying to do?
       As usual, showing actual actions with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
    > either. [...]
    things?
    • DewyB's avatar
      DewyB
      The "Switch" is connected to a cable modem.
      " "tried" how?  Some web browser or other?  On some computer/device or
      things?
      I have tried logging in with Chrome and IE to router login.com and .net as well as the ip's mentioned.
      Each attempt was met with address refused connection.
      I am trying to open port 2593 to incoming traffic.
      Thank you for your prompt reply.
      • > The "Switch" is connected to a cable modem.
           Not a very detailed description of anything.  What is this "a cable
        modem"?  Is it a simple modem or a modem+router?  (A maker and model
        number would normally reveal all.  "a cable modem" reveals almost
        nothing.)
           If your "a cable modem" is only a modem, then connecting multiple
        devices to it (through a switch) it is probably a poor idea.  If it's a
        modem+router, then you could have a chance.
        > [...] What, exactly, was your "my defalut gateway ip"? [...]
           Still a mystery.
        > [...] I have tried logging in with Chrome and IE to router login.com
        > and .net as well as the ip's mentioned. [...]
           What's the IP address of your (unspecified) computer/device?  For a
        DOCSIS cable modem(+router), you might also try "192.168.100.1".
           Why?  "incoming" to what?  Assuming that that makes sense, that would
        be a router function, and we still haven't located your router (if you
        have one).
