BcV
Apr 10, 2018Follower
Netgear modem not working with xfinity.
My modem stopped connecting to the internet a week ago so I called the xfinity tech to check it out. He said the network was fine and it was the modem not connecting. So I went a bought another Netgea...
gibboneyb
May 24, 2019Initiate
Did you find a solution to this problem? I Also have a R7000 and xfinity internet. Wife and I just bought a new house and switched from Cox at the old house which worked fine to xfinity at the new house and im having the same issue. Every week or so the wifi network will change from what we named it back to NETGEAR70. The top three lights will blink then all lights will pop on and the cycle repeats itself for 10 mins or so. I have to log in to my routers IP and then rename the wifi networks for it to work again. Any solution will be helpful
May 26, 2019Guru - Experienced User
Do you have R7000 router or a C7000 cable modem router? If a R7000, please post here:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
If a C7000 cable modem router, please make a new post and post more details so we can help you.
gibboneyb wrote:Did you find a solution to this problem? I Also have a R7000 and xfinity internet. Wife and I just bought a new house and switched from Cox at the old house which worked fine to xfinity at the new house and im having the same issue. Every week or so the wifi network will change from what we named it back to NETGEAR70. The top three lights will blink then all lights will pop on and the cycle repeats itself for 10 mins or so. I have to log in to my routers IP and then rename the wifi networks for it to work again. Any solution will be helpful
