Sho's avatar
Sho
Follower
Jun 18, 2016
Netgear N600 cable modem router model C3700
N600 is acting strange today (this morning), my PC was not able to connect to yhr router, after power off and on, power led light on, a few seconds later, the next 3 led lights flash 6 times simultaneously, then all led lights on once, then all off except the power led light, wait a few seconds, the next 3 led lights flash 6 times simultaneously again, then all led lights on and off again, appearing it was forming a boot failure cycle, trying to, but can't, boot, again and again.
What does the 3 led lights (down stream, up stream, and Internet) flash 6 times mean? (trying to tell me something?)
Thanks for your help!
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Sho
    I would try to factory reset the modem if that fails you may want to check with your ISP could be a connection issue. And if something is wrong with the modem you may want to contact Netgear support if your modem is still under warranty.
    DarrenM
