Konanpa's avatar
Konanpa
Initiate
May 28, 2020
Netgear Nighthawk C7000v2 Wireless work fine but no wired connection via LAN
Just purchased C7000 Nighthawk - installation was easy.  worked with ISP provider Cox.  No issues.  Wireless is working fine.  However, I cannot get the modem/router to recginzie any of the LAN ports.  Have tried resetting and turned on and off.  Netgear genie shows 3 of the 4 connected LAN and indicates that they are allowed.  Lights on the back of the modem/router to the LAN ports are all yellow with occastional flash.  No green lights.
Any suggestions in allowing the LAN ports to connect?
  • FURRYe38's avatar
    What LAN devices do you have connected?
    Be sure to swap out LAN cables with good quality cables, CAT6 is recommended.
    • Konanpa's avatar
      Konanpa
      Initiate
      I used the previous cable I had with prior device.  They are CAT6 cables.  Any other ideas on why these devices wouldn;t register.  It is to my Samsung TV, Panasonic Blu-Ray and my Denon Receiver.
      • FURRYe38's avatar
        Do you have any wired devices that are working when wire connected or is all devices not working over wire?
        Has a factory reset and setup from scratch been performed since last update?
