AyeeItsWillis's avatar
Nov 22, 2021
Netgear Nighthawk c7800 low upload speeds
So I just recently noticed that my upload speeds on my c7800 modem router have been really low on my gaming consoles. Download speeds are what they have always been, but upload speeds have gone from the usual 10 mbps to 2.0-5.0 mbps. I am also having constant packet loss in games which is really frustrating. This used to not happen a couple of months ago so I have no idea what is going on. I have also tried port forwarding and that did nothing. The device is on the latest firmware and I have already contacted my ISP so that they can send a technician to come take a look at their wiring and stuff to see if that is the issue. Any ideas on what it could be? Thanks.
  • plemans's avatar
    What wired speeds do you get on a pc/laptop?
    Do you have a screen snip of the cable connections page and the event logs?
    • AyeeItsWillis's avatar
      AyeeItsWillis
      I cannot test wired speeds on a pc or laptop because I am using a macbook which doesnt have a ethernet port. I will attach the cable connections page and event log snips.
