a_o
Oct 09, 2022Aspirant
Netgear Nighthawk CAX80 + 1.2Gbps Xfinity Internet + Windows 11 Home + Driver version 22.160.0.4
Modem + Router: Netgear Nighthawk CAX80 ISP: Xfinity Comcast 1.2Gbps OS: Windows fully updated to Windows 11 Home 22H2 Device firmware/hardware has been fully updated from Lenovo Vantage + indivi...
a_o
FURRYe38 - appreciate the speedy reply.. lmk if you need anything else...
What is the brand and model# of the wifi adapter in this PC? - Intel(R) Wi-Fi 6 AX201 160MHz
Ethernet speeds to spec? - 800-900
Try a different wireless PC to compare? - my laptop is a Lenovo Legion gaming(specs attached) vs work Lenovo P1 Gen 3 (they both have the same wifi adapter (see attached photo) same distance same wifi adapter gaming is more spec'd out but idk
What FW is loaded on the CAX? - screenshot attached
How is the wifi configured on the CAX? - not sure what you mean by configured but here's what i have for the following:
-AX enabled
-2.4GHz bgnax (chan 4) - up to 1200Mbps mode, 100% power transmit
-5GHz(only i'm on) - (chan 48) - up to 4800Mbps mode, 100% power transmit
Is Smart Connect enabled? - nope
Oct 09, 2022Guru - Experienced User
Is the drivers for the wifi adapters up to date?
What are the speeds seen when Smart Connect is enabled?
How are the Advanced Wifi Settings configured on the modem?
