DB001's avatar
DB001
Netgear Nighthawk CM1200 Fails to connect and lock to all channels and internet fails
Hi Netgear,
I am consistently having internet issues and drops (1-2 times per week) while on zoom calls for work.  My provider is RCN and they cannot troubleshoot because the modem is not leased from them.  They were able to point me in the direction of the Modem diagnostics and they noticed that not all of the channels are bonding and locking.  It is consistently only half of the channels.  Can you explain why all of the channels are not bonding and locking?
I can send you the error log and screenshots but is there any security concern by making the details in the log public?
Thanks,
D
  • plemans's avatar
    No, there isn't issues with posting the cable connectino info and logs.
    If you have any splitters, amplifiers, or attenuators in line. I'd remove them.
    Check the line for kinks, damage, poor/cheap connectors.
    • DB001's avatar
      DB001
      I've attached the logs.
      • plemans's avatar
        so check the line. Preferablly move the modem to right where the coax enters the home. This ensures nothing in the home is causing the issue. Also remove splitters, amplifiers, or attenuators from the line.
