Cloud500
Jun 27, 2020Aspirant
netgear nighthawk x10 r9000
Hello my router keeps randomly disconnecting everyday and can be fixed using a factory reset, but today nothing works it just says ethernet cable is not connected or plugged but it is and the internet icon on the router is not onand number 6 is blinking orange. It is frustrating because I literally cannot find any solution on the internet other than returning it back, but I have it since 2-3 years now
I have tried the 30-30-30 reset the 7 second reset
The resetting sequence with modem and changing my ethernet cable but nothing works!!!!
Please help
Please help
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.- Cloud500AspirantAlright
