leeguth
Sep 04, 2018Follower
NETGEAR Nighthawk X4S DOCSIS 3.1 (C7800) phone port
I recently purchased this router because it was on Comcast's list of certified modem/routers. When the installer came to install everything we found out there is no phone jack. He said they've run in...
vkdelta
Sep 04, 2018NETGEAR Employee Retired
For using Voice service, you need C7100V (Voice Wi-Fi Router) or CM500(Voice modem only). These are the only 2 NETGEAR retail devices which work with voice.
You can alway go with 3rd party voice service such as OOMA (www.ooma.com) instead of using Comcast voice. You will need to buy their hardware and connect behind C7800. they charge a small monthly fee as well I guess. This is not officially support by NETGEAR but it is an alternative to using Comcast voice service.
walruspete
Sep 14, 2018Guide
Does NETGEAR plan on developing a DOCSIS 3.1 compliant cable modem w/ telephony?
As of now, there are DOCSIS 3.1 modems and ethernet/telephony modems but not any that are both DOCSIS 3.1 designed with voice.
- vkdeltaSep 15, 2018NETGEAR Employee Retired
I dont think anyone wont comment on future plans here but I would keep looking netgear's website every month or so and any press releases.
