dlwilladsen
Feb 18, 2025Tutor
Netgear repairs?
Does Netgear repair any out-of-warranty products, like my CM1100? Or, does it just make no sense, considering shipping and repair cost?
- Feb 18, 2025
tends to indicate failure. If its not in warranty, probably time to buy a new one. they'll charge more than a new one is worth.
If you're on xfinity the coda56, netgear CM3000, and Arris S34 all support the next gen speeds. (coda56 is much cheaper)
Feb 18, 2025Guru - Experienced User
Not that I know of.
and usually its not cost effective.
what failed on it?
dlwilladsen
Feb 18, 2025Tutor
Don’t know. Just all lights be a-blinkin. Power green, up, down, internet amber (lan1/2 both solid amber). Nothing resets it. Doesn’t matter what’s plugged into it. Had another thread “led’s mean what”.
- plemansFeb 18, 2025Guru - Experienced User
