dlwilladsen
Feb 18, 2025Tutor
Netgear repairs?
Does Netgear repair any out-of-warranty products, like my CM1100? Or, does it just make no sense, considering shipping and repair cost?
- Feb 18, 2025
tends to indicate failure. If its not in warranty, probably time to buy a new one. they'll charge more than a new one is worth.
If you're on xfinity the coda56, netgear CM3000, and Arris S34 all support the next gen speeds. (coda56 is much cheaper)
dlwilladsen
Feb 18, 2025Tutor
Don’t know. Just all lights be a-blinkin. Power green, up, down, internet amber (lan1/2 both solid amber). Nothing resets it. Doesn’t matter what’s plugged into it. Had another thread “led’s mean what”.
Feb 18, 2025Guru - Experienced User
