Jason7181's avatar
Jason7181
Netgear switch GS116 V2 will not connect to Netgear C7000-100NAS
Whenever I connect the Netgear C7000-100NAS to the Netgear switch GS116 V2 I loose all internet and wifi. It used to work and then all of a sudden I lost all internet and wifi.  I disconnected the GS116 V2 switch and then WiFi and internet come back.  I have moved the cords arounnd the switch and nothing changes. I plug into the back of the modem/router and get full service as long as the switch isn't contected to the modem/router. The other thing that I noticed is if I unplug the modem/router from the switch lights start to blink on the switch where the cables are attached. The power light is on when and doesn't flash.
Cable to modem/router and then switch connected into back of modem/router.
Looking for help.
  • FURRYe38's avatar
    Connecting LAN port #1 or #4 of the modem to LAN port #1 or #16 on the switch?
    Ensure your inbetween LAN cable is of good working quality. CAT6 is recommedned. Swap out LAN cables for a known working cable between the modem and the PC to test.
    The switch is unmanaged so should be plug in play with out any configurations.
    • Jason7181's avatar
      Jason7181
      I have tried connecting lan port #1 or #4 of the modem to lan port #1 or #16 on the switch and it still no internet.  I have tried all different combinations and still cuts the internet out. I have also unplugged the router and switch and then rebooted both of them. Also have done a factory reset on the modem/router. I'm starting to wonder if the switch is bad. But I'm not sure why it would cut out the internet.
      • FURRYe38's avatar
        Try a different switch to see.
        You did swap LAN cabling correct?
        Try the switch with a different router if you have one, just connect them gether with a PC to see if it works. You don't have to connet the router to the internet or modem.
