bosherboi's avatar
Feb 01, 2024
Netgear WiFi router/modem combo PLEASE HELP!!!
I am in serious need of a new modem/router combo ASAP, DOCSIS 3.1, either dual or tri band, for WiFi 6+ 6E to be able to handle up to 1G with capability to transition and handle WiFi 7 (firmware?). Also must be compatible with Xfinity
I use Xfinity "Gigabyte Extra" service (advertised as 1200/200, reality 500/650 up/50 down). I do not live in an area that has been upgraded to the "Next Gen Network".
Ive been looking at the Arris Surfboard G54 ($599) capable of handling speeds up to 1G, the Nighthawk AX2700, and the Nighthawk CAX30 and CAX80
Can anyone make a recommendation based on my specs?? Greatly appreciate any advice and direction!!
  • FURRYe38's avatar
    NG doesn't have any cable modem gateway that support WiFi 6E at the moment. NG doesn't give out on what's on the future production plate either.
    CAX30 and 80 only support WiFi 6
    I'd get into a separate ISP cable modem unit, something that the ISP supports. Then add on some thing that supports 6Ghz or Wifi 7:
    Orbi 960 or 970 series
    Nighthawk RS700
    • bosherboi's avatar
      bosherboi
      Star
      So you are suggesting a stand alone modem and add a mesh system instead of a router/modem combo?
      I currently use the aforementioned combo (moden/router) and use the DECO W7200 mesh system.
      Whether its a stand alone modem or router/modem combo, I need to do something now as the current combo has outlived its usefulness as it only delivers up to 300mbps. My current speeds are 400-600 up to 1G.
      What models can you recommend?
      • FURRYe38's avatar
        Take a look at what your ISP supports for stand lone modems. Netgear's CM series model modems are all stand alone. CM2000 series being most available and released to the market. There is a CM3000 that's been on the burner however not due out anytime soon. Not sure when either. That's up to NG and they don't give that info out.
        Something CM series if your ISP supports it and then a Orbi MESH system mentioned earlier or if you need a bit cheaper mesh system, review the Nighthawk MK90 series system.
