techfreak8
Sep 26, 2016Aspirant
Netgear Wireless Data Cable Gateway firmware update
Netgear CG4500BD Current firmware is 1.03.03. The gui is ancient looks like it is from 2003. I want to update firmware to modern gui genie. Problem is I bought this modem from amazon and not from cox. Cox is only one that provides firmare update but I am not cox user, I have optimun. So how can I update firmware is there a zip file I could have so I can do it maually?
- techfreak8Aspirant
Any help much appreciated :)
- DarrenMSr. NETGEAR Moderator
Hello techfreak8
All firmware on cable modems come from the ISP you are connected to no way to manually update the firmware.
DarrenM
Alright then if I contact my isp optimun about this issue will they be able to upgrade the firmware?
